Posted by soundguy on February 02, 2012 at 17:24:54 from (107.41.212.242):
In Reply to: M not charging. posted by Ellis Kinney on February 02, 2012 at 16:33:17:
i kinda just went down this path with my H.
came with a newish, non working junky chinese regulator.
I dinked with it and cleaned up the contacts and had to tweak them to make them strike correctly, and rigged up a tickle switch while waiting for parts...
I got one at napa that was worse.. and didn't work.
finally got one at car quest that works ok.
if you can ground the field and make the ammeter show charge.. it's simply a regualtor field circuit issue...
if that works.. get back with us.
if not, then pull the belt off and motor test the geny.. if it motors, then it should charge.
get back to us for a detailed set of tests to bypass the cutout and field..
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
