Re: Rod bolt lockwasher
Posted by Owen Aaland on February 02, 2012 at 19:48:49 from (216.47.34.30):
In Reply to: Rod bolt lockwasher posted by tntleake on January 31, 2012 at 14:09:02:
When those machines were built torque wrenches were almost unheard of. Safety wire, Pal nuts, and locking tabs were ways of keeping fasteners with too little tension to stay tight from working their way apart. Once fastener strengths became standardized and torque specs were established that ensures enough tension so things would not work their way apart safety wires and locking tabs were mostly used on only critical fastener applications.
