Re: 350 Farmall Questions
Posted by Janicholson on February 02, 2012 at 20:21:09 from (96.24.99.126):
In Reply to: 350 Farmall Questions posted by 1sarge on February 02, 2012 at 20:10:14:
A Farmall 350 for 500 with a suspect engine is a good price. If the engine is free it is much less hassle to fix. If it has coolant in the oil, it should be able to be leaked out of the drain plug into a pan to assess what it is. If it needs all drained out, then do it. You will not buy a usable running tractor in its class for less than 2500. If you are adverse to repair work, work with a FFA group for a project. It would be a Buy for me! Jim
