Posted by gene bender on February 03, 2012 at 03:24:39 from (67.55.226.231):
In Reply to: M not charging. posted by Ellis Kinney on February 02, 2012 at 16:33:17:
If you dont have one get a meter so you can check for ground the whole system needs a ground even the sw on the steering post. Then check the voltage on the batt terminal on the reg then when the engine is running check the voltage on the A term. You do have the gen A term going to the GEN term on the reg and same with Field on gen going to Field on reg. Try simple test when the engine is running ground the field if that shows charge the reg is bad and if it doesent show charge the gen isnt working
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
