Posted by D Slater on February 03, 2012 at 05:45:01 from (184.15.39.154):
In Reply to: 350 Farmall Questions posted by 1sarge on February 02, 2012 at 20:10:14:
Could be a replacement block or at a overhaul the engine size was changed to 175 and someone decided to stamp the block. Casting # near the C175 would help identify it, or check for a block serial # stamped in just above the tin side cover on the same side looking on toward the front of engine. Engine date code is also between the side cover and head. If that was the complete serial # of the tractor posted before a 300 would have no dipstick originaly with that #. 350 had a key switch not in the gage panel. Hydraulic valve shaft selector sticking above the sheet metal on most. Something not likley to get switched between tractors was the clutch pedals. At lower end the 300 has a bolt and jam nut to limit throw. 350 doesn't have the bolt. Depending on location I would sure be interested in the tractor if you don't want it.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
