Get ready to expend a lot of elbow grease. I start out with a pressure washer. Then I put newspapers under it and soak it in oven cleaner for a couple of days. While it is soaking, I take off parts that are in the way of painting or cleaning, I sand blast the removed parts if they are in rough condition. I use a cup brush in an angle grinder, a hand steel brush, putty knife, anything that will remove dirt and grease. Don't sandblast the assembled tractor, don't get oven cleaner on anything you don't want to paint, it will remove or discolor the original paint. After the oven cleaner soaks awhile, it needs to be pressure washed 1 or 2 more times. Be sure all cleaner is removed or your new paint won't stick.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
