charge the battery. Remove the rubber hose from the carb. Have some help, and make sure it is in Neutral, put your hand over the intake where thr hose was removed. Have the helper crank the starter for 2 seconds. Heavy suction on your hand will tell you that it is making vacuum correctly. If the engine starts, Good. if not, check inside the distributor cap to see if there is moisture or carbon tracks that would keep spark from getting to where it belongs. Jim
Today's Featured Article - New Hitches For Your Old Tractor - by Chris Pratt. For this article, we are going to make the irrational and unlikely assumption that you purchased an older tractor that is in tip top shape and needs no immediate repairs other than an oil change and a good bath. To the newcomer planning to restore the machine, this means you have everything you need for the moment (something to sit in the shop and just look at for awhile while you read the books). To the newcomer that wants to get out and use the machine for field work, you may have already hit a major roadblock. That is the dreaded "proprietary hitch". With the exception of the
... [Read Article]
Latest Ad:
[More Ads]
