Posted by Janicholson on February 04, 2012 at 07:06:45 from (96.24.99.126):
In Reply to: cub charging to - posted by swagger d on February 04, 2012 at 01:44:42:
Square #1 Do you want it to be as it was from the factory? we need to know if it is distributor or mag, 6volt or 12. If you want it to be stock configuration it needs to be positive ground. Make sure the battery is connected so the positive post is connected to the chassis of the tractor, and the negative post is hooked to the starter switch. If you want it to be negative ground, put negative bat post to ground. Next (before anything else including starting it) jump between the Bat terminal on the VR to the Arm/Gen terminal for one second. This polarizes the gen. It will spark. Now start it and run it to 1/2 throttle or more. If the amp gauge moves right, all may be well. If it moves left, do the following: With the engine off, turn on the lights. If the amp meter moves to the right, carefully mark then remove the wires from it and put them on the opposite posts. now start it and see if it moves right at 1/2 throttle. If so check the charge rate. If the battery is charged the voltage should be 7 to 7.2 volts. If it needs some charging it could be closer to 6.6 to 7 volts, but that is OK. All of the above depends on the wiring being correct for the Cub with generator. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
