Re: Re: need help fast
Posted by Garnet Best on September 10, 2000 at 11:01:57 from (142.177.58.13):
In Reply to: Re: need help fast posted by The Red on September 09, 2000 at 10:40:52:
Glenn I think there was a misunderstanding. What I was trying to say was take it apart, clean up the crank, throw the old rod away and install a new rod. Been there and did that twice. Not on the same engine. I'm a slow learner. Was lucky both times. On the 5 hp Techumseh rod broke but no other harm. It was in snowblower with old oil working hard on mild day. On 16 hp Techumseh in 1816 B Case skid steer just ran out of oil. Like yours engine got too tight to run or start again but didn't quite seize. Both ran fine with a little polishing of crank and a new rod. That plus a gasket or so is far cheaper than a new engine if the rest of the machine is good.
Post A Followup
: Re: Re: Re: need help fast
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
