Re: H not starting
Posted by Janicholson on February 04, 2012 at 15:35:45 from (96.24.99.126):
In Reply to: Re: H not starting posted by John V on February 04, 2012 at 14:55:58:
Remove that nut on the bolt (Actually a stud) that is glowing. Make sure the insulator between the stud and starter frame is good! It could be melted!!
use sand paper on the battery cable end, and the stud and nut. They must be shiny and clean. If it then starts great, put some corrosion inhibitor on the stud/nut. If it still glows and heats up, take the starter for a rebuild. Jim
