Re: Cub transmission
Posted by Jim Becker on February 04, 2012 at 16:56:18 from (71.252.156.130):
In Reply to: Cub transmission posted by Chief 83 on February 04, 2012 at 16:19:33:
Does the lever throw as far into third as it does the other 3 gears? If not, the lost 2-3 detent ball may be lost into the space of the transmission housing where the shift rail slides forward. If so, the rail can't slide completely into third gear.
