The bolts I repaint are usually cleaned with a wire brush on a grinder and primed and painted by hand and stuck into holes in a piece of plywood, etc. By the time of assembly I have usually forgotten what goes where and just look for them. On parts like a starter or generator I might just sand the body or use a wire brush on an electric drill as such parts are too small for an angle grinder. I tape off the label. From there they are cleaned with wax and grease remover, primed with epoxy and painted with urethane just like everything else. The bolts are touched up after assembly, or sometimes replaced with cadmium plated bolts, if I have not already used several cadmium plated ones, as I don't want too many of them. I try to make the shiny bolts blend in with rest of the tractor. I keep the decent unused dot heads in case I want to use them for something else.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
