Re: SMD Live Hydraulic Pump
Posted by TWheat on February 05, 2012 at 04:16:29 from (76.6.198.34):
In Reply to: Re: SMD Live Hydraulic Pump posted by sflem849 on February 04, 2012 at 15:28:44:
The pump may care which way it turns. I did some checking on this 7-8 weeks ago. I don't know how much difference there is between the MD and SMD, but what I understand is on the MD there is an idler gear that turns the pump in an opposite direction than the gas. Which turns the Mag in a reversed direction from the gas, but that the Mag can be changed to fire correcttly in either direction. If it is a distibutor, if IRC, the part #s on the distributor are the same for the gas and deisel, so I haven't understood that yet.
I had some good info on the RPM site under Engines and Jim Winehouse (hope spelling is right)who posts here knows more about them than I do.Just saying, check it out.
