Re: Firing Order stamped on block should mean?
Posted by El Toro on February 05, 2012 at 07:56:21 from (108.3.225.57):
In Reply to: Re: Firing Order stamped on block should mean? posted by fort steele tractors on February 04, 2012 at 16:26:15:
So they would go in this firing order. Hal
PS: You may need to bring No1 piston to TDC on the compression stroke to see where your rotor is pointing.
1-2
3-4 rotor turns CCW
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
