Re: Super A steering arm assembly
Posted by gene bender on February 05, 2012 at 09:06:10 from (67.55.226.231):
In Reply to: Re: Super A steering arm assembly posted by DRL on February 05, 2012 at 07:39:10:
The two assys i have both are the square ones.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
