Re: Cub transmission
Posted by Chief 83 on February 05, 2012 at 10:45:12 from (24.21.76.219):
In Reply to: Cub transmission posted by Chief 83 on February 04, 2012 at 16:19:33:
Well it's fixed! No broken shift fork. Jim had it exactly right. The "lost" detent ball was indeed inside the shift rail space. In fact so was the one on the other rail. Must be a little more room on that one as it shifted properly over there. So if anyone needs some 3/8 ball I've got a box of 45. You guys are scary on what you know. Thanks a bunch.
