You can make or have made something like the original. One way is take the end of a one inch bolt with a nut. leave threads about 1/2 inch above nut, slide 1-1/8 long 1 inch pipe with threads on end away from nut. Weld or braze bolt to pipe down inside good enough to not leak. Cut lower end to length and weld a 1/2 inch bolt with threads down to that. Not room in there for a big nut if one inch all thread was used. Cut 1-1/2 inch pipe on a angle to fit inside of the housing. Use a big washer on pipe and use the 1/2 threads to tighten down. Removed one that they just stuck a pipe down through housing with a pluged collar on the end and stacked washers between housing and collar. Didn't sit straight though. Picture of original parts included.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
