Re: Plumb my auxiliary valve
Posted by D Slater on February 05, 2012 at 14:00:48 from (184.15.16.112):
In Reply to: Re: Plumb my auxiliary valve posted by W.Brehm on February 05, 2012 at 11:51:33:
Yes its a stage 2. Remote control valve was a attachment. All tractors didn't have it. I put the 2 part numbers in a picture for mounting fittings on the housing for a stage 2 with engine driven pump. Part with threads goes up, lower side goes in the hole and the wedge and bolt are used inside the housing to retain it. Valve fittings go on the threaded end.
Operators manual for a stage 2 should have a picture of hookups outside housing and how it operates.
