Re: Plumb my auxiliary valve
Posted by Mike1972chev on February 05, 2012 at 15:50:40 from (99.137.203.196):
In Reply to: Plumb my auxiliary valve posted by W.Brehm on February 05, 2012 at 08:29:53:
DSlater gave you the best photo of what you need,but are hard to get.
Super MTA mount is TOTALLY different than what you need.Super M TA bolts to the housing with 3 bolts.Super M is on that special "stud" with 1" pipe on one end and bolts ito the housing with a special wedge washer.You can make one.
If you do weld one up,make sure the already sealed pressure side of what you are doing is what you are welding the trans mount to. DO NOT set a 1" pipe on top of a 1" bolt and weld it to it expecting it to hold pressure.You could get hurt !!!!
