Re: PTO
Posted by Janicholson on February 05, 2012 at 15:53:22 from (96.24.99.126):
In Reply to: PTO posted by kbeatty on February 05, 2012 at 14:52:15:
It can be removed easily (I would drive the tractor into a depression, or back it up onto the ramp part of a loading dock to get the front about 18 to25 inches below the rear). This moves the final drive oil to the front allowing the PTO to be removed. Once out you will see a coupling that is moved by the PTO shifter. It is probably worn in the splines or dogs and needs to be contoured to not jump out of gear. It can also be replaced if the system is too worn to fix. Jim
