Re: PTO
Posted by Tony_Idaho on February 05, 2012 at 18:34:11 from (184.99.117.253):
In Reply to: PTO posted by kbeatty on February 05, 2012 at 14:52:15:
I have a Farmall 450, so I not sure if this would be the same...
My PTO would turn fine and dandy, but while I was driving, it would just suddenly stop turning. Fought this for a long time, but there was a simple solution once I actually looked at it. Apparently the person that I bought the tractor from didn't believe in cleaning the linkages, at all. So, when I looked it was actually full of dirt where the little lever that keeps the PTO engaged. apparently the little lever was just barely latching so any bump would cause it the come out and the PTO to slowly stop. Once that was cleaned out, never had the issue again.
I hope this could be the case for you, cause I was thinking about tearing into the PTO also, Glad I didn't have to.
Best of luck finding the issue.
  • Re: PTO Janicholson 06:37:00 02/06/12 (0)
