Re: Pulling tractor
Posted by Farmalldan on February 06, 2012 at 19:00:43 from (50.12.220.90):
In Reply to: Re: Pulling tractor posted by sflem849 on February 06, 2012 at 18:49:57:
If I were to use the JD A would I need a special clutch? and would it be fine to just shave the head0.001 off. with a budget in mind what would be a cheek list of things to do to it? thanks
