Re: Farmall H M Ploughing: Steel v Rubber Wheels
Posted by CNKS on February 07, 2012 at 05:34:16 from (216.144.104.128):
In Reply to: Farmall H & M Ploughing: Steel v Rubber Wheels posted by SadFarmall on February 07, 2012 at 01:10:59:
I have never noticed any damage to any rim except when the tire changer bends it with a hammer. I did plow once with steel wheels. Perhaps not a good test but I couldn't tell any difference from rubber. As to loose ground, you don't plow in loose ground and the traction is probably better with steel. Steel does not slip but "may" need a little more power than rubber. I have repeatedly pulled a tandem disk with steel, and again could not tell it from rubber, both loose and firm ground. This was on an H.
