Re: Pulling tractor
Posted by Andrew Z on February 07, 2012 at 05:57:01 from (64.148.7.32):
In Reply to: Pulling tractor posted by Farmalldan on February 06, 2012 at 18:05:07:
Power for pound the Super C will have the cheapest power. The slant dash A's are geared high and often run out of power stock in the 4500lb class. A Super C will be good power wise in a 3000lb class stock, with the overbore you will be set for 3500lb even 4000lb class in some pits. A good 30ish hp Super C would cost you around 300 for a piston and sleeve set, 75 to get the head decked some other minor tweaking 50/75 so for about 400ish you have a decent starter puller. The A would be considerbly more have to bore out or find power block more head work etc, really the trans holds that one back.
Andrew
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
