Re: magnato or coil converstion
Posted by gene bender on February 07, 2012 at 06:01:11 from (67.55.226.231):
In Reply to: magnato or coil converstion posted by Shawn Brown on February 07, 2012 at 05:53:11:
You can tell if the rotor is timed correct if you will make a mark on the body where the towers are that the sparkplug wires go. Then remove the cap and turn the engine over then check if the rotor stops at the mark before it snaps. The gears turning the rotor can be timed so the rotor will line up with the tower when it snaps. Sounds like that is the problem as it will make them hard to start with the starter but pulling will make it run.
