Re: IH UB 220 power unit mystery (long)
Posted by Buzzman72 on February 07, 2012 at 09:48:38 from (74.129.196.127):
In Reply to: IH UB 220 power unit mystery (long) posted by TractormanNC on February 07, 2012 at 07:01:14:
Basically, what you have is a version of the old Black Diamond [BD] 220 truck engine. There were two variations on this engine, the straight valve and the tilt valve...straight valve being the older of the two and a direct descendant of the old SD-220 truck engine.
So determine whether you have the straight valve or the tilt valve engine, and then look for parts for the truck engine. If you get a valve cover gasket set or a top engine set, it may come with two valve cover gaskets. If the narrower one fits, it's a straight valve engine; if it takes the wider one,it's the tilt valve engine.
Pistons ARE different between the straight valve engine and the tilt valve engine; use the wrong one and you'll ed up with something like 13:1 compression instead of the stock 6.5 or 7:1.
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
