This is what you need for Standard Tread tractors like the OS6. This is a 650 system. Any W400 thru 660 system could be modified to work. The same goes for other makes that use that type of system
Just yesterday I received a backup system (cylinder, linkages, bracket) for my 660. The drag link systems are very rare. It was only the second IH system I have seen on eBay in about 10 years.
Your tractor was not offered with PS. A system off a W400-W450 will be close if not a direct exchange on a OS6.
I think a torque generator would work but it will require some work (machining and welding) and the destruction of the stock IH shaft and column.
I installed a four port hydrostatic steering "hand pump" on a W400 last year because the drag link was in my way for installing a homemade implement. That was a considerable amount of work and a fair amount of money. It also requires a cylinder on the front axle.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
