There may be confusion between steel wheels and rubber tire rims. If you see rubber tire rims bent, there is a metallurgical problem with the Australian rims, I have seen a few bent rims but they were from smashing into solid concrete in 4th (no longer hanging around, so no issue) I have never seen a IH front or rear rim bent from field work, and there are bowling ball sized rocks in the fields. If they are steel "tires" they should be 1030 or higher carbon steel and 1/2" thick. Rubber tires add a cushion between the drive train and implement. Gears and bearings last longer. Jim
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition.
... [Read Article]
Latest Ad:
[More Ads]
