Posted by Hugh MacKay on March 12, 2009 at 14:31:34 from (209.226.106.187):
In Reply to: Re: Sure enough! posted by ScottyHOMEy on March 12, 2009 at 12:47:25:
Scotty: I like that terminology, VERBAL LUBRICATION", must remember that. I must admit, I once found myself in a similar situation working alongside a member of the clergy.
Read my most recent responce to Pete, I'm not 100% certain I did this without splitting the tractor.
That 2001 clutch assembly replacement in my 130 is an event I'd just as soon forget. I had everything necessary of the tractor for the actual split when 3 friends walked in and proceeded to help. As I recall 2 hours later the tractor was back together same point as when the guys walked in. After they left I tried to get clutch adjustment, no way.
I went to lunch and returned to split the tractor again only to find clutch disc in backwards. I think depressing the clutch pedal with disc in backwards is what actually bent the fork. When I removed the old clutch disc, I placed it in front of blocking under clutch housing, facing the proper direction. I went out to my truck for the new assembly. I later learned one of my friends picked up the old clutch disc and examined it. He must have put it down the opposite way and I went by that. There is something to be said for working alone on these projects, parking one's posterior on a 5 gallon oil can, long enough to make sure no mistakes have been made.
I know now that I straightened that fork on that second split that night. I didn't get the fork exactly right, thus release bearing carrier turned a 1/4 turn on me twice. The fishing through hole was getting release bearing carrier back in place It has stayed as long as I keep pedal free travel to bare minamum.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
