Posted by sflem849 on February 07, 2012 at 16:31:19 from (69.197.84.39):
In Reply to: Splitting an M posted by George Rausch on February 07, 2012 at 11:42:08:
Dr. Bert said: (quoted from post at 17:08:31 02/07/12) Tractor Vet: Are the holes in the clutch housing countersunk so that more than a 1/4 inch of bolt sticks through or into the backing plate. Is there enough wobble in the bolts to let the rear end of the block sag while rolling it forward and possibly breaking the front engine supports? In other words, are the top and bottom bolts on the rear of the frame rails dedicated only to secure the backing plate to the rails, or is the backing plate threaded to hold the block while rolling it forward and gettingenough room to insert the bolts that have been remove?[/quote:059e2ec2d4]
I'm not The Vet, but nope. They are both clearance holes. If you are really hardcore you can use the stand to hold the frame rails and a floor jack to hold the tractor. When I did the MD I just rolled it forward then put the bolts back in when there was room. I guess that would be a pro of rolling the rear away.
[quote:059e2ec2d4="Dr. Bert"](quoted from post at 17:11:41 02/07/12) What keeps the rear of the engine from dropping down until you can slip the bolts back in?
Nothing unless you don't take the bolts all the way out.
This post was edited by sflem849 at 16:33:06 02/07/12.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
