Re: Splitting an M
Posted by John M on February 07, 2012 at 17:19:02 from (67.231.174.220):
In Reply to: Re: Splitting an M posted by Dr. Bert on February 07, 2012 at 16:11:41:
Dont take the 2 bolts all the way out, if I recall, you can go a good inch out before you really need to take them out to go any further. Then you can slip the bolts back into the frame rails and backing plate. If you dont put the bolts back in, the back of the engine will drop once the those top bolts are out, and you clear the aligning dowels. The are the 2 bolts are in will hold the engine in place, or at least Ive never had anything break back there, as TV implys. (Id almost bet its can happen, and has happened to him)
