Re: M oil pick-up
Posted by rustred on February 07, 2012 at 18:27:44 from (74.200.18.156):
In Reply to: M oil pick-up posted by jdntn on February 07, 2012 at 17:57:55:
all is well.thats the way they work. the pumps usually dont give much trouble. you could probably clean out the relief valve in the body since it may be sticky too, but should be allright. you can check the oil pressure once its running should be 38-46 lbs.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
