Re: still farming with an M
Posted by mkirsch on February 08, 2012 at 05:24:06 from (64.80.110.75):
In Reply to: still farming with an M posted by jdetig1 on February 07, 2012 at 15:20:24:
Yeah man, everyone, and I mean EVERYONE is looking for a "good used" set of tires. Even if someone has a line on a set they're going to snap them up for themselves rather than share the info with you. It's the reality of the times; new tires cost more than the entire tractor is worth.
15.5x38's are the same outer diameter as a 13.6x38 when mounted on a proper rim. They would be fine for an M, as they will not increase speed but will increase flotation.
15.5's should be mounted on a 14" wide rim IIRC. Good luck finding a 14" wide drop center rim. I think 12" is as wide as they get.
If you're desperate, you can squeeze the 15.5's on to the M's stock rims in a pinch.
