Re: M oil pick-up
Posted by Yooper Farmall on February 08, 2012 at 07:09:44 from (141.210.112.16):
In Reply to: M oil pick-up posted by jdntn on February 07, 2012 at 17:57:55:
Depends on your oil pressure, mine gets too low when the engine gets warmed up. On Rustyfarmall's suggestion, last night I took the bottom cover off the oil pump, the surface is worn from contact with the gears. I plan on taking the cover to the machine shop today to have it ground or milled flat again. That seems to be the least expensive oil pump work I can have done, I have priced out replacement parts from the local Case-IH dealer, gets expensive quick!
Gear and shaft $360
The idler gear below that with 12 teeth, $104
Oil regulating valve $39
Spring below the valve - $12
Gasket below the cover $5
Pickup screen with nozzle into the cover $42
Oil pan gasket $14
