Re: Replacing flywheel ring gear Chapter 2
Posted by rhtx55 on February 08, 2012 at 17:04:10 from (207.119.59.31):
In Reply to: Replacing flywheel ring gear Chapter 2 posted by Dr. Bert on February 08, 2012 at 16:06:41:
After removing from the crank, they come off very easily with a little heat applied, not red, just warm enough to expand a bit, then tap with a hammer a few times to the rear.
The next morning,after cleaning the recess well & shining up just a bit with some emory heat & install the new one. Then have the flywheel clutch surface turned again to get it perfectly flat.
Some good advice above about checking everything over while you have it split. Pilot bearing, throw out bearing, rear engine seal, front tranny seal, clutch disk, & pressure plate.
This post was edited by rhtx55 at 17:08:30 02/08/12.
