Re: Replacing flywheel ring gear Chapter 2
Posted by pete 23 on February 08, 2012 at 17:21:07 from (74.32.238.142):
In Reply to: Replacing flywheel ring gear Chapter 2 posted by Dr. Bert on February 08, 2012 at 16:06:41:
You can just knock it off easily, problem is when in vertical position on tractor , you don't have gravity working for you when you want to install it. You need to heat it evenly and get it on quick. When flywheel is laying down they just drop into place but on engine you may have to tap it into place. You can just turn them around and use other side unless it is really chewed half way to the other side. They no long bevel the teeth on new ones on either side.
