Re: Replacing flywheel ring gear Chapter 2
Posted by Haas on February 08, 2012 at 18:12:11 from (75.246.61.209):
In Reply to: Replacing flywheel ring gear Chapter 2 posted by Dr. Bert on February 08, 2012 at 16:06:41:
I did the ring gear on my Farmall C without taking the flywheel off. I used a punch to drive off the old ring gear and then heated the new one before installing. As I recall, I had to use a hammer to drive the new one on, but it was not a problem to do so.
