Re: IHC chapter#7 Going for the plowed mile again!
Posted by Mike1972chev on February 09, 2012 at 03:55:38 from (75.149.81.173):
In Reply to: Re: IHC chapter#7 Going for the plowed mile again! posted by Ole three bottom on February 08, 2012 at 18:49:27:
Thanks for jumping in "Ole Three bottom".(I DO NOT want to "misrepresent" this IHC #7 event.)
I cant wait tho do it! I might be hitting you up for some plow advise if I get stuck?
Good times :)
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
