Re: Auxiliary valve parts update
Posted by Mike1972chev on February 09, 2012 at 10:39:43 from (75.149.81.173):
In Reply to: Re: Auxiliary valve parts update posted by W.Brehm on February 09, 2012 at 04:46:44:
You have to have the lower cover off to get to it 9/16 socket. Once you get inside there is 1 bolt holding it on against that big, "wedge" washer.I believe it is either 7/16 or 1/2 bolt,so you will need a 5/8 11/16 or 3/4 socket,(cant remember wich???)but you need a LONG extention for your 1/2 ratchet take a selection of 12" and 6' extensions with a swivwel for the socket end. No trick to it! ;)
