Re: H carb trouble
Posted by Nebraska Cowman on February 09, 2012 at 14:24:40 from (66.252.115.26):
In Reply to: H carb trouble posted by dcpky on February 09, 2012 at 13:28:01:
I had a carb I rebuilt one time. The rubber tip on float valve would stick shut. I finally took it apart and rubbed dirt on the valve.It never stuck again.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
