Re: H carb trouble
Posted by Fixerupper on February 09, 2012 at 18:09:11 from (199.120.105.202):
In Reply to: H carb trouble posted by dcpky on February 09, 2012 at 13:28:01:
Float hanging up? The hinge and pin can wear and let the float hit the side of the carb. If it's the original it's been sloshing around in there for 64 years. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
