Posted by Janicholson on February 09, 2012 at 18:09:27 from (96.24.99.126):
In Reply to: H carb trouble posted by dcpky on February 09, 2012 at 13:28:01:
Also look for a stuck float. It can touch the sides of the bowl and hang up. Bend it gently and check it if it rubs. THe little tab on the float that pushes on the needle can be crooked and cause a stuck needle as well. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
