Re: H carb trouble
Posted by NDIHguy on February 09, 2012 at 21:25:29 from (216.147.172.189):
In Reply to: H carb trouble posted by dcpky on February 09, 2012 at 13:28:01:
I agree with Rusty check your gas cap and make sure its vented and if it is make sure its not plugged. when it starves, run it with the cap off and see if it clears up.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
