Re: Question on the E85
Posted by rustyfarmall on February 10, 2012 at 06:45:59 from (216.248.71.224):
In Reply to: Question on the E85 posted by uncle henry on February 09, 2012 at 21:01:06:
I have a 1940 H equipped with a Woods belly mower. I replaced the head on that H early last spring with a fresh, rebuilt, high compression gasoline head. Other than new valves and seats, the head is stock. After the initial start up and adjustments were made, I then filled the gas tank with E85 and began cutting grass. The H ran GOOD, but did have a slight hesitation when pulling the throttle open quickly. I opened the main load screw an additional 2 full turns, for a total of 5 turns out, and that did help with the hesitation, but did not cure it completely. I think I need to open the carb, take out the main metering stem and drill the inlet holes out just a wee bit so more fuel can get to the engine.
Other than the slight hesitation and slightly longer warm up time being needed, that old H performed flawlessly running on straight E85, and I parked the tractor late last fall with E85 still in the tank. Time will tell if that was a good idea or not.
Yes, the E85 did clean the tank. I had to empty the sediment bowl only twice.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
