Re: H carb trouble
Posted by rustyfarmall on February 10, 2012 at 06:49:41 from (216.248.71.224):
In Reply to: H carb trouble posted by soundguy on February 09, 2012 at 13:28:01:
A Farmall H carburetor float would have to be twisted quite a bit before it will rub the sides of the fuel bowl. Yes, it CAN happen, but not nearly so readily as the float in the M carburetor.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
