Re: 460 pto?
Posted by ejr-Ia. on February 10, 2012 at 11:40:51 from (204.11.182.14):
In Reply to: 460 pto? posted by tractordanp on February 09, 2012 at 16:12:33:
The two types of PTO's will have a different rpm because of a drive gear ratio in the front drive houseing.The band one is the slower geared one over the one with clutch disks.I put a clutch disced one in one time I thought the grinder was going to gernad.
