Re: Question on the E85
Posted by IH fan on February 10, 2012 at 14:20:50 from (108.67.113.94):
In Reply to: Question on the E85 posted by Chester5731 on February 09, 2012 at 21:01:06:
That's odd... there's less BTUs in alcohol, so you should lose either Hp or mileage, or both. To get the same HP, you would need to feed it more fuel. S-i-l has a flex-fuel car and if he runs E85 he loses between 15-20% mpg. When he first got it, E85 was enough cheaper that it still paid to use it. Suddenly they raised the price of E85 to almost the same as E10 and it was cheaper to run E10 or regular.
BTW, if I go to Iowa, E10 is cheaper than regular, but here in KS the E10 is higher... wonder why that is? Must be taxes or something.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
