Posted by Brownie 450 on February 11, 2012 at 08:06:05 from (66.43.241.198):
In Reply to: 706 wont start posted by Diesel1 on February 11, 2012 at 07:30:29:
What does a small amount of ether do--if you've tried that? Do you have 12 volts to the dist. terminal while cranking? Less with the ignition switch on & not running [resistor in circuit]? Have you got the plug wires in the right order in the dist. cap? If you've got that good of compression & vacuum, it should fire. You do have good spark, don't you? I'm assuming you have tried advancing & retarding the dist. while cranking?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
