Re: 706 wont start
Posted by gene bender on February 11, 2012 at 08:08:10 from (67.55.226.231):
In Reply to: 706 wont start posted by Diesel1 on February 11, 2012 at 07:30:29:
When the piston is at the top on compression is the rotor pointed to #1 tower on the dist cap if it is it will start you dont time the dist to the oil pump. Remove #1 plug so you can see when the piston is at the top with a mag lite then you will see if the rotor is pointed at the tower.
