Re: H carb trouble
Posted by gab on February 11, 2012 at 08:21:29 from (50.103.17.219):
In Reply to: H carb trouble posted by dcpky on February 09, 2012 at 13:28:01:
When it acts up shine a flash light in the tank and make sure there's nothing over the tank outlet. Fifteen or twenty years ago when it was 20 below and a blizzard ever other day around here I was warming up my Super C and decided a bottle of heet would'nt hurt. When I popped the little white cap off the bottle it bounced off the tank into the tank. What can that hurt, right? Probably a month later it would spit ,sputter and die and then be ok again. Had the carb apart and every thing else and then it stopped in a snow bank and would'nt run at all, shined a flash light in the tank and there was the bottle cap I forgot about positioned perfectly over the tank outlet.
Also make sure you gas cap vent is not plugged.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
